Temp Gauge, Fans, other problems..
Old Aug 28, 2010 | 02:49 PM
Iroc'nthe87's Avatar
Car is an 87 350 TPI dual fan set-up. The temperature gauge is pegged to the absolute bottom and does not move ever.. I believe the gauge is controlled by the green wire on the drivers side manifold (connects to the *temp switch?* need to clarify that), Or would it have something to do with the coolant temp sensor? The green wire looks to be in good shape, not melted, etc..
Fan issues to come later..
Old Aug 28, 2010 | 03:05 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Temp Gauge, Fans, other problems..
Temp sender--(?)
The one that tell the gauge what to say-- has that been replaced?
IMHO, it is important to know the temp so it is known if the fan(s)
work & at what temp comes on..??...
Old Aug 28, 2010 | 03:10 PM
As in where the green wire connects to on the drivers side, below the exhaust manifold? then no it has not been replaced (yet)
I also ground out the green wire and the gauge still does not move. I'm beginning to think the gauge is bad.
Old Aug 30, 2010 | 11:48 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Gage Rage
When you start the car (when the key is in the START position) does the gage move?
If no, the gage is bad or there is a broken connection to it, and the bad connection is in the dash.
If the gage moves when the key is in the START position, the you have a bad connection from the gage to the sensor, or the sensor is defective.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Old Sep 2, 2010 | 06:37 PM
bobbysk's Avatar
Re: Gage Rage
i have similar prob in 91 305 tbi except green wire is not present (see new posting). i am wondering if wire is broke and where it traces back to in wire loom. My gauge does properly peg on startup too.
Old Sep 7, 2010 | 09:50 AM
NINÅ's Avatar
Transmission: 765R4
Wire Mire
That green wire runs from the gage, to the ignition switch, to pin 4 of the right side dash connector, to pin F5 of the bulkhead connector located on the left side of the firewall below the relay bracket, to the sender.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Sep 8, 2010 | 08:55 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Re: Wire Mire
grounding the green wire will not cause the gauge to move...merely read zero.
To move the gauge requires resistance. Try a resistor between green wire and ground. Gauge movement tells you that the sender has malfunctioned with this test. 50 ohms or so should give a reading...I'm unsure of the low and high values right now. Of course no reading would indicate a problem with the wire itself.
Hope this can be helpful.
Old Sep 8, 2010 | 10:13 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Wire Mire
Grounding the gauge causes it to peg. NINÅ already explained the easy/correct test above.
The ignition switch grounds the sending lead on the gauge causing the gauge to do a full sweep test during start (crank). Grounding the lead to the block should produce the same result.
That's how it is. It's worked that way on GM gauges since at least the late '60's.
Old Sep 9, 2010 | 05:46 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Wire Mire
Practically every tempurature sensor used in any automobile today is a "negative coefficient" thermistor. Negative coefficient means that as temp increases, resistance decreases. Therefore less resistance will cause a higher temp reading and grounding the sender circuit will peg the gauge. Careful with this test though as it can damage some gauges.
Old Sep 9, 2010 | 10:30 PM
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Re: Wire Mire
yeah my bad...got confused with the fuel gauge...been a while since I played with them. Been working on some warning circuits but on the shelf at the moment.
Apologies for my misinformation....wasn't thinking right.
Old Sep 12, 2010 | 12:21 PM
Turns out my gauge was stuck! Had to remove the plastic gauge cover and move the needle. Good deal!
Old Sep 15, 2010 | 11:58 PM
Dany89's Avatar
Im having a similar problem except that my needled goes all the way to to red zone but im certin is not overheating, i just changed the temp sensor, the fan switch,and the coolant temp sensor. any idea what else could be wrong???
Old Sep 16, 2010 | 12:01 AM
Dany89's Avatar
Re: Wire Mire
Happy Racing!
Hey when your talking ab out the pin 4 and pin F5 where exaclty are those
Old Sep 16, 2010 | 09:39 PM
deadbird's Avatar
Engine: TPI 305/ v6
Re: Wire Mire
that's the gm label for the circuit or, contact point.
f5 is in the firewall harness that NINÅ stated. pin 4 is the cluster plug (seen w/cluster removed). may be mildly different between cam & bird.
Bubbajones_ya
Jul 6, 2024 08:32 PM
tommy z-28
Oct 6, 2015 10:58 PM
corey8084
Sep 17, 2015 02:56 PM
86IROC112
Sep 11, 2015 04:04 PM
85Special
Sep 3, 2015 04:21 PM
