Some ac questions
Old Sep 1, 2010 | 10:24 AM
DirtDawg57's Avatar
Some ac questions
I am redoing my a/c or at least what I can afford right now. I bought a accumulator from napa but it didn't have caps in any of the ports? Is this a problem? I didn't know if that would allow a lot of moisture in to and cause problems.
My second question was my compressor makes a clicking noise when it is running. When I bought my car it has some charge left and so to see if it still worked I added some r12 but not any oil. Do you think this clicking means its already damaged or could adding new oil to the system quiet it down. I haven't ran it since it started the noise except 1 time by accident. Thanks!
Old Sep 1, 2010 | 01:13 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Air Apparent
The accumulator should have come with caps.
You should return it for a new one.
TIP: Put a secret mark on it, and all returned parts so they won’t be able to resell it to you in the future.
RE: Your noisy compressor, can’t tell without hearing it.
If it is ruined you have nothing to lose by adding oil.
If the system then works correctly you win.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
