Fan shroud..
Old Sep 13, 2010 | 02:01 PM
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
Fan shroud..
hey, one of the bolt holes on my upper fan shroud broke off..is there another way to keep it down? heres a pic:
Old Sep 13, 2010 | 02:48 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Fan shroud..
The cheap, ******* way would be to just stick a large washer under the bolt head to hold it down.
A better way would be to cut a small tab from some sheet metal to hold it down.
The correct way would be to replace the whole piece.
Me, I would just cut a small tab from sheet metal for it and use that. It should work just fine and if you paint it to match the shroud you won't notice it unless you're looking for it.
Old Sep 13, 2010 | 03:26 PM
vinny83's Avatar
Re: Fan shroud..
its one of them things only the owner of the car notices, and it pisses me off lol. ill try the washer idea. i wasss gonna just self-tap screw it down..
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
