Heater vent control not working
Old Oct 14, 2010 | 10:38 AM
jdparsons1's Avatar
I just helped a buddy change out his bad heater core and in the process of putting everything back together must have knocked something loose. When we finished the heater core replacement, before putting the dash back together and the computer back up into the dash we tested and the vent control was working properly. After putting everything back in it now blows through all vents no matter what the control is set on. First question, is this electrically controlled or vaccum operated? Anyone have any idea what, in that area of the dash i should look for?
Old Oct 14, 2010 | 04:05 PM
Drew's Avatar
Re: Heater vent control not working
The system of doors that controls where the air blows out of the dash is controlled by vacuum. The hot/cold control is controlled by a stiff wire from the HVAC controls to the heater box.
Look for loose or broken vacuum lines. Also you might want to check the control valves on the HVAC control unit. There's two of them (3 & 12 in the diagram), and they like to break and leak. Usually when that happens (or the vacuum line is disconnected under the hood) the vents default to defrost.
The_Phoenix
Feb 4, 2016 07:10 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
mustangman65_79
Aug 11, 2015 03:17 PM
