Noob question head bolts
Old Oct 21, 2010 | 08:35 AM
rockskater3's Avatar
Hi, im new to this site, and i have a noob question. i recently changed the head gaskets on my 85 trans am 305 LG4, I torqued down the heads, but i didn't use teflon paste, and im still getting water in my oil, do i need to use teflon paste? thanks.
Old Oct 21, 2010 | 10:06 AM
jac113's Avatar
Car: 1992 Camaro
Engine: LB9
Transmission: WC T5
Axle/Gears: 10 Bolt - 3.42
Re: Noob question head bolts
It's highly recommended if not a necessity. Usually head bolts will come with a coating on them already at the bottom. I even put black RTV at the top of the bolt, not sure if it was a good idea or not but its done. If you reused the same bolts without adding teflon that might be your problem or you have a crack somewhere in your block.
Either way, I wish you the best, replacing the heads on mine was a chore and and hope I don't have to do it again unless i'm putting on some Vortecs.
Old Oct 21, 2010 | 10:42 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Thread sealer on head bolts is absolutely a necessity.
Old Oct 22, 2010 | 08:27 AM
thanks guys, i had no clue, chiltons repair manual had nothing about sealing the bolts, anyways thanks again
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
