How many Air dam pieces are there?
Old Nov 5, 2010 | 12:39 PM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Transmission: 700r4 built
Axle/Gears: 3.42 posi 10 bolt
I took the old broken upper air dam off because there was hardly anthing left to it. I am trying to find a replacement for it, but I am not sure how many pieces there should be. I see a three piece. Then I see a lower air dam.
Heres this, but I didnt think transam took the same as firebird?
http://cgi.ebay.com/ebaymotors/82-90...item33623f4279
then after that is mounted is there something that goes onto it?
I looked at all of the firebird pictures, but it was hard to tell how many there are. Btw this is on a 85 firebird
Old Nov 5, 2010 | 12:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Re: How many Air dam pieces are there?
It's different for different cars. Some 'Birds had 3 piece designs, some had the single piece. All of the Camaros that I know of had a 1 piece design, except for some of the SC's that had it kinda 'built' into the front nose or ground effect. Makes it confusing I know.
If it helps any, the 3 piece jobs had the main piece directly under the radiator (like the Camaro), and the two extras were on each end, and kinda angled towards rear of car if I remember correctly.
Sorry I'm not more help. Any of the designs you should be able to 'rig' up under your car (with the exception of the SC style that was built in to the nose).
Old Nov 5, 2010 | 12:54 PM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
I would say mine is the three piece since it looks like were it attaches there are parts of the old sides still connected. Is there still a piece that connects to the three piece design though.
such as http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Nov 5, 2010 | 01:12 PM
Car: 1992 RS
Engine: Carbed 350
I don't think so. I think that last ebay item is an alternative to the 3 piece. Might be for the base model firebird - kinda looks like what's 'built-in' on the base model Camaro nose piece (the SC model I was referring to).
Old Nov 5, 2010 | 01:16 PM
Car: 1992 RS
Engine: Carbed 350
I should mention that just about anything under there will work. The Camaro RS and IROC have a simple straight piece about 3ft long and maybe 4 in tall that bolts directly under the radiator. The purpose is to create a vacuum behind the radiator so that fresh air is 'sucked' in through the front of the radiator from the vacuum. Some think it pushes air through the front, but it does not - it creates this low pressure area (vacuum) and thus air automatically rushes in to fill the low pressure void thus going through the radiator. Many have taken sheet metal etc. and just made their own. The design is not as critical as the simple having of something there to create this low pressure area. Hope that makes sense.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
87iroctheo
Dec 4, 2016 11:47 AM
krisner89
Oct 10, 2015 06:03 AM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
