Cooling Fans on Constantly
Old Feb 21, 2011 | 01:45 PM
suhz88's Avatar
Car: 88 IROC-Z
Engine: 5.7
Transmission: 5-spd
Axle/Gears: D44 3.73
As soon as I turn the key the fans go on. I know this can't be normal. Can anyone tell me how to fix them? Thanks!
Old Feb 21, 2011 | 02:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Cooling Fans on Constantly
Either there is an issue with your fan switch (located pass side head between #6 & #8 spark plugs, or a previous owner has hacked up the wiring to make them run constantly (probably because an issue with the factory fan switch).
Old Feb 21, 2011 | 02:17 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
It could also be the relays themselves, but I'm not sure where they are on the camaros. I know they were near the radiator on my 88 GTA though.
Old Feb 21, 2011 | 06:16 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Exactly what happened to mine. All because the sending unit wire got charred.
Old Feb 22, 2011 | 08:47 AM
suhz88's Avatar
Car: 88 IROC-Z
Engine: 5.7
Transmission: 5-spd
The 'hacked up' wiring is definetly a possibility. It looks like a plate of spaghetti inside there. When they swapped out the engine there was no thought to making the wiring easy to follow...it's just 'there'.
Thanks for the suggestions, I'll check it out tonight.
Ce
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
