coolant leak...kinda
Old Feb 26, 2011 | 01:12 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
I've got coolant coming out of the weep hole on my water pump. Not a lot, just a little drizzle when I shut the engine off. I'm guessing this means a new water pump. Any other ideas, suggestions? Never changed a water pump before so this should be interesting.
Steve
Old Feb 26, 2011 | 01:15 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: coolant leak...kinda
Are you sure its not coming from the intake manifold or thermostat housing and running down the front of the motor? Almost every single GM engine has intake sealing issues in one way, shape, or form. If you're sure its the water pump then it shouldn't be too difficult, just a belt and four bolts. Make sure you use some thread sealant on the bolts when you reinstall them.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
