Is this the a/c high pressure switch?
Old Feb 26, 2011 | 04:12 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
Is it supposed to be capped like that if you only have one fan?
I have this blue and brown plug I'm trying to find out what it plugs into.
Old Feb 27, 2011 | 12:38 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Is this the a/c high pressure switch?
That looks like a fitting for a/c. But for the filling of R134a. I cant remember where the high pressure switch is on my car for sure. I'll look in the morning and get back to ya if no one else has.
Old Feb 27, 2011 | 06:04 PM
kingzrt's Avatar
Car: 1987 IROC-Z
Engine: 5.0 305ci 4 barrel Edelbrock carb
That is your high pressure line. It should be capped if you only have one fan.
Old Mar 2, 2011 | 02:22 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I think your high pressure switch is that thing with two two wires going to it on the very back of the receiver-dryer silver canister from this angle
Old Mar 2, 2011 | 02:37 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The high pressure switch is located on the compressor. (to shut down when pressure gets to high)
There is sometimes a switch on the high pressure line, but that is to turn on the sec. fan when the A/C comes on.
The switch on the dryer closes the clutch when A/C is engaged.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
jackhammer
Aug 15, 2015 10:04 PM
