Upper Radiator Hose Issue
Old Sep 3, 2011 | 02:13 PM
Desmodaeus's Avatar
So, I noticed today after mounting the alternator on, that my ribbed upper radiator hose will not fit around it. I also have the straight thermostat housing, not the one bent toward the driver side. Does anyone know what hose will work for me there? I have a 92 camaro with a carbed Crate 350.
Old Sep 3, 2011 | 06:29 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: Upper Radiator Hose Issue
You could use some Romex wire (interior house wire) or similar item (coat hanger?) and mold it to the shape of hose you need. Then look the the hose inventory at the local parts store for the shape and size you need.
Old Sep 4, 2011 | 07:26 PM
Desmodaeus's Avatar
So far I've returned 3 hoses and still haven't found one that works. There has to be some hose that works...
Old Sep 6, 2011 | 06:40 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Just get a 90* thermostat housing, I have this one on my motor:
http://www.autozone.com/autozone/par...mString=search
Only $7, and it wont warp because its cast iron. Than that opens up your radiator hose selection.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
dyeager535
Aug 28, 2015 08:10 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
