Removing air dam!
Old Sep 29, 2011 | 01:24 AM
shone190's Avatar
Removing air dam!
Does anybody try to remove air dam on Firebird and make a hole in bumper for radiator cooling?
I'm seek of scratching everything with air dam, so I want to remove it
Old Sep 29, 2011 | 07:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Removing air dam!
Many over heating issues involve missing/removed air dams. I'd keep it in place unless you can fab something that will effectively replace it--and still look cosmetically pleasing.
Dragging the dam occasionally is simply a part of owning these cars.
JamesC
Old Sep 29, 2011 | 07:56 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Even the camaros with the through the grill vents use the air dam. Don't booger up your bumper.
You may also want to replace your saggy springs to keep it from dragging.
Old Oct 15, 2011 | 07:03 AM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Yup, the 83 Z28 was always "hot" till we bought an air dam and put it on. It forces air upwards in front of the radiator so it can flow though the radiator. Removing the air dam reduces the air flow through the radiator.
Old Oct 15, 2011 | 10:14 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
There's bumper structure on front of the rad, and you can't cut that away.
Old Oct 22, 2011 | 10:04 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Heck, I had a 1980 malibu that would get hot at speed, it was because the air dam was gone. And it had a vvery good sized grill.
Old Nov 9, 2011 | 11:32 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Third gens are bottom feeders, they need the air dam.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
87iroctheo
Dec 4, 2016 11:47 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
