why is this radiator hose here?
Old Nov 30, 2011 | 11:23 AM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
first off i have a stock radiator. On the passenger side the topmost large hose (right beneath the hose for the resevoir tank) from what i understand used to connect to the heater.
Now this hose is connected into the top of my intake manifold (holley street dominator intake). It connects just to the side of the thermostat housing.
I dont understand why that hose is there. My car no longer has any ac or heat.
Old Nov 30, 2011 | 11:55 AM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Re: why is this radiator hose here?
That's the coolant bypass for when the thermostat is closed. The SBC has a bypass built into the block but it isn't enough for high reving engines. If you rev your engine high, keep it. If not, you can cap both the intake and the radiator. This hose can also run from the intake to the water pump.
Old Nov 30, 2011 | 12:28 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
the engine is a 5.7 1990's block with a 480 lift cam, headers, and a holley 650 carb.
I want my car to warm up faster. Will it if this hose is removed?
i only rev the car high when doing a quarter mile or rarely i do quick acceleration.
I run at 2000 rpm cruising is the city. On the highway i run between 1600 and 2100 rpms that between 60 and 85 mph
Old Nov 30, 2011 | 01:04 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
I would keep the hose but return it the the WP instead of the radiator. Get two 1/2" npt X 3/8" barb connectors and a 1' long piece of 3/8 hose and make the hose run from the intake to the WP. Then cap the radiator inlet.
Old Nov 30, 2011 | 01:15 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
No reason to be "reving high" when the thermostat is still closed.
Old Nov 30, 2011 | 01:28 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
thanks will do that
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
