Not Getting Heat
Old Jan 7, 2012 | 12:16 PM
92GTAkid's Avatar
Car: 1992 Trans Am GTA
Engine: 305 5.0L
Transmission: Manual 5-speed
Not Getting Heat
1992 Pontiac Firebird GTA, no heat coming out at any heater setting, but AC works fine. Previous owner was in Florida. Any ideas on what I should check first before thinking about replacement parts?
I know very little about this stuff, so please be patient with me if I ask any dumb questions.
Old Jan 7, 2012 | 12:24 PM
AmorgetRS's Avatar
Re: Not Getting Heat
First thing to check is if the heather core has been bypassed. There are two hoses on the passenger side that run to the firewall near the heater box, make sure they make it.
Old Apr 1, 2012 | 08:33 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Once you verify the hoses are there, what does your temp gauge read? Does the car ever "warm up"?
Old Apr 8, 2012 | 12:14 PM
92GTAkid's Avatar
Engine: 305 5.0L
If you mean 'warm up' by the temp gauge on the dashboard going up? Yes, it goes to just before the 220 mark. It's the heater part of the A/C system that isn't working. No matter what temperature I set the slider to, it's always cold.
Old Apr 8, 2012 | 12:32 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Turn the car on and put it on heat, take the radiator cap off and see if any coolant is coming from the hose that goes to the firewall, I've seen some people just shove a wooden dowel into the hose to stop it. Also the a/c is for cold, not heat. Heater and a/c are 2 different components.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
