Help with cooling fan switch/sensor...
Old Jan 26, 2012 | 05:06 PM
severedknight7's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 V-8
I got this 86 trans am with a 305, holley intake and carb. It's an obvious PO job, butchered wiring everywhere, and i am tired of having the fan on all the time. I found the switch/sender on the passenger side of the engine, and noticed it has only one blade hookup. So my question is, what color wire goes to it? And I hope and pray it will kick on my fan when needed. Oh and one more question. There is something attached to the very back of the intake, it seems to be related to coolant, it has a two blade hookup which is attached to another doohickey with a single blade hookup. I have no clue to what this is. Thank you for any help on these matters.
Last edited by severedknight7; Jan 26, 2012 at 05:11 PM. Reason: forgot to add something.
Old Jan 27, 2012 | 11:34 AM
Engine: 305 V-8
Re: Help with cooling fan switch/sensor...
hello?
Old Jan 27, 2012 | 12:09 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
On my 1986 Camaro, the factory single cooling fan sender is a two wire clip with a black wire and a black with a red striped wire. Regarding the doohickey, can you post a photo so we can see what you're talking about?
Old Jan 27, 2012 | 06:47 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
The fan switch wire should be green with a white stripe. It may be grounded somewhere causing the fan to be always on with the key on, or they may have intercepted it over at the fan relay by the brake booster. Probably grounded the wire due to failure of the fan switch, but hard to say. Try tracing it from the fan relay. Fan relay is the one with 4 wires going to it. Red or orange for positive lead,black with red stripe for positive to the fan,skinny brown or gray is switched 12 volt and green with white stripe grounds out the relay
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
