quick question for my duel fans
Old Mar 13, 2012 | 09:08 AM
mattyc's Avatar
Car: 1998 grand cherokee, 1988 iroc z
Engine: 350 tpi
Axle/Gears: ???
They don't work,the wires are all hacked up, so... I want to wire them up to just turn on when the car is started and just have them run. I have been looking at the schematic below and trying to figure which wires need to spliced for this to happen. i think i have a general idea but i want to make sure I'm on the right path. I do not want a switch inside the car.
https://www.thirdgen.org/forums/cool...-diagrams.html
this is what im thinking,
take the ignition wire and splicing it with the blk/pink and the blk/red and making sure the blk is grounded.
Old Mar 14, 2012 | 05:48 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: quick question for my duel fans
Easiest way would be to ground the green with white stripe wires going to each one of the fan relays and let them control the power wires. That's a lot of fan going at once. Maybe try one at a time?
Old Mar 14, 2012 | 06:32 PM
mattyc's Avatar
Engine: 350 tpi
Axle/Gears: ???
I only hooked one up, ran the car for about 45 minutes in park, the car stayed at 160ish. theres a bad ground somewhere and cant seem figure it out. Im eventually going to be getting a relay kit with a temp sensor and run new wires. i was just checking i was not going to have a car fire.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
