91 Camero RS Overheating
Old Jun 20, 2012 | 12:13 PM
Michelle Turner's Avatar
My RS is over heating big time. The temp gauge is broken and dosn't register anything at all but will 'reset' itself upon starting. It only over heats while idling or at lower speeds. I've been leaving my heater on to keep it from over heating too much while I'm driving.
The temp sensor has been replaced and I took it to a dealer who said it was the EMC. Everything I find on EMC's doesn't help me much. Can someone tell me what the possibilities could be for the car over heating and where I can get a new EMC for the cooling fan?
Old Jun 21, 2012 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 91 Camero RS Overheating
Welcome to TGO, Michelle.
Camaro. ECM. You might consider a search as there aren't many questions that haven't been asked and answered here on TGO. To start with the simple: Is the fan (fan's) coming on? Is the lower air dam in place?
Best of luck with your project.
JamesC
Old Jun 21, 2012 | 10:16 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Possibilities: too much crap (oil,dirt,etc.) on the side of the block, thermostat, clogged hose(s)/raditator, water pump, fans, no air dam, bad head gasket. There are actually 2 temp sensors, one is in the plenum and the other is on the underside of the block right above the starter. I believe the temp sensor is in the plenum and the fan switch is above the starter. Getting hot at low speeds and idle isn't giving much of an idea as to what the problem is, have you noticed anything else?
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
