91 RS Overheating help?
Old Jun 24, 2012 | 06:41 PM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Alright im stuck now :\. My car is getting hot now, it does pretty fast too. It will get near the red and back down about a millimeter and stay. It gets hot super fast if i run my ac. All the hoses get hot, but my coolant overflow tank doesnt fill up like it used to, any suggestions?
Old Jun 24, 2012 | 06:45 PM
Jk_Under's Avatar
Engine: 305 5.0L
Re: 91 RS Overheating help?
Before anyone helps, the fan runs all the time, it runs when my ignition is on. On my temp gauge there are 5 lashes, the first being the coldest 5th being the hottest and the 3rd is the mid(where it should be) it stays a tad below or above the 4th lash (which is bad)
Old Jun 24, 2012 | 06:49 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Check the fluid level in the radiator, add as needed.
Fill recovery // over flow to the cold level.
If all is good there, IDK.
Old Jun 24, 2012 | 07:00 PM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
^^ then check thermostat?
flush the cooling system, fill with proper mix of antifreeze and water.
Old Jun 24, 2012 | 07:13 PM
Jk_Under's Avatar
Engine: 305 5.0L
thermostat has been replaced 4 times in the last 2 months
Old Jun 24, 2012 | 07:57 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Troubleshooting Order for overheating (in order of cheapest/least effort/likelihood):
Inspect coolant level/ check for leaks - repair leak and fill (also check oil for milky texture indicating bad head gasket)
Check Fan Function- Make sure a/c is off.
Inspect Air Dam/fan shrouds- You'll run hot without these
Inspect Hoses- check for leaks, collapse during operation, etc.- replace as necessary
Inspect Radiator- replace if badly corroded, bent or leaking
Thermostat- replace and Fill Coolant
Radiator Cap- If it's old just replace it. You'll overheat with a bad one.
Water Pump- Replace, Fill coolant
If you go through that list and you're still overheating, you either have a serious or complicated problem or a defective new part. More serious problems include a bad head or head gasket or lean running condition.
That's just a reference list for anyone having an overheating problem. Just thought I'd try to sum up cooling troubleshooting in a nutshell.
Old Jun 25, 2012 | 04:40 PM
Mishimoto's Avatar
You're not leaking coolant from anywhere?
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
