defrost only, yes ive searched, help!
Old Jul 1, 2012 | 11:51 AM
DennisCarithers's Avatar
Ok so I've used the search feature and found nothing, there is a vaccuum line on the top rear of my motor with a screw in it, my vaccuum diagram shows that it is the line to go to the HVAC but I cant find where to route this hose, does is go into the firewall? It's an 88 iroc z with a 305-350 swap, pics would be greatly appreciated
Old Jul 1, 2012 | 11:55 AM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Re: defrost only, yes ive searched, help!
Black plastic hardline comes out of the harness going across the back of the engine bay. Towards the passenger side.
I am dubious that you searched as that is a fairly well-known issue.
Old Jul 1, 2012 | 12:02 PM
Ok thanks ill check it out in a few minutes, all could pull up with search was the selector switch making a hissing noise
Old Jul 1, 2012 | 12:25 PM
I can't seem to find that line, can you post pictures?
F-body-fan
Jan 12, 2023 01:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
paul_huryk
Oct 1, 2015 04:27 PM
kkirch15
Sep 30, 2015 04:44 PM
