Don't underestimate the airdam effect
Old Jul 13, 2012 | 05:50 PM
nhgator's Avatar
Car: 1985 T/A
When I put the car back on the road,with no airdam,you couldn't go over 35 without the gauge shooting to 230 in no time.
I couldn't locate a airdam localy,so just for giggles I made one from some conveyer belting I had kicking around,what a difference,after a 1 1/2 hour ride from 30-75 mph in 93 degree heat the gauge never read over 190.
Old Jul 13, 2012 | 05:56 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Don't underestimate the airdam effect
Thank you for the info. nhgator, I have been working on mine and I have just finished the fan shroud.
Old Jul 15, 2012 | 10:47 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
99.9% of overheating is caused by some component of the air dam failing.
Old Jul 15, 2012 | 10:53 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Only at speed - if you are stopped in traffic, air dam is doing nothing.
Old Jul 15, 2012 | 11:05 AM
mantaguy's Avatar
Engine: 5.0 EFI
Not really,all the parts need to be in place to keep the air that is flowing in from the fan to operate at maximum capacity.The temp. will rise in traffic of course,but not to the extent of overheating,that's why the fans kick in at 230 degrees.
Old Jul 15, 2012 | 11:24 AM
nhgator's Avatar
Car: 1985 T/A
Even yesterday,in stop and go traffic to New Hampshire Motor Speedway it never got over 195,me and my son with no a/c were pretty hot though,should took the old Dodge Ram,at least the a/c is working in that.
Old Jul 15, 2012 | 11:35 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Depends on the weather. Haven't had one on mine for 4-5 months now (damaged by curb), and was surprised to find it runs fine, so haven't got round to replacing it yet. Only gets to about 210 after a half hr high-speed driving, sits about 180-190 in traffic so I'm happy for now.
Only getting away with it cause it's winter here though - it will definitely be needed again once the summer temps get going, impossible to run without it then.
My fans kick in a hell of a lot lower than 230 though; motor's usually showing signs of distress by than.
Old Jul 18, 2012 | 02:33 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Correction, I'm an idiot
For anyone searching - the air dam I removed recently was the one I fabbed up years ago - got crushed up against a curb. I completely forgot that I REPLACED it again, temporarily, with the original factory air dam that I took off (or what was left of it). It's split and bent backwards - the reason I replaced it when tackling overheating issues many years ago.
Probably is still at least partially doing it's thing
Old Jul 18, 2012 | 08:40 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
That is due to GM designing the cars to rely on the airdam for cooling. Pretty much a bad design flaw that can be remedied, but rarely is.
Old Jul 18, 2012 | 10:15 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
You would need an upgraded dual fan cooling unit plus upgraded radiator to run without the air dam, although the cooling effect it has on the highway is worth it's weight in gold.. It's a 50$ flimsy piece of lightweight plastic that does a great job of cooling.
Although here's food for thought.. You know how everyone's air dam scrapes on everything? Well, what if you bolted it on an angle (such as the old school muscle cars have it at like the 69 camaro) then it would not be as low to the ground AND would probably cool better since the air would be diverted upwards more towards the engine?
Old Jul 18, 2012 | 10:27 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
It's a way to compensate for not having a front grill I guess, allows us to have that 'stealth' look. I really can't see how it has any effect when stopped at idle, or in stop-go traffic - there is no or little forward speed to generate any airflow for it to deflect. It's all about the fan(s) then.
Of course, at sustained cruise rpms for any duration, it is a requirement. Even my busted-azz one.
Old Jul 18, 2012 | 10:35 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
That's just what I did with the one I made up out of galvanised aluminium, was more of a scoop at about 30 degrees to the horizontal. Worked very well for many years but was gathering damage bit by bit, until I wiped it out good
Old Jul 18, 2012 | 11:09 AM
Was the cooling on par with what it was at the stock angle? And how did you damage it if it was higher than stock? I would assume it would scrape alot less?
Old Jul 18, 2012 | 12:51 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
I believe that new, the stock one is angled forward just a little. My stock one is bent backwards, has about an inch scraped off the bottom, and is split at the top. This is why I replaced it. I made one myself, because at the time I couldn't source a new one locally for a sane amount of money.
So I can't really say if my version cooled better than an undamaged stock one, but in the summer months here it did a WAY better job than the messed up stock one. There's been quite a few guys on here that have done something similar, search around. Seems to be an area of great creativity - eg think I saw a guy who made a hinged one.
There's plenty of things something hanging off the bottom of a car can find to hit, esp one this low! The stock dam at least has a bit of give being plastic; my sheet metal one fared worse. Lasted about 8-9 years though, got to replace it again before summer hits.
Old Jul 25, 2012 | 02:27 AM
Blackknight's Avatar
This will be a stupid noob question but the air dam is that the piece that is connected to the front bumper and goes underneath the car parallel to the underside of the car? Or is it the one that kinda comes down from the radiator area or even both? I know I don't have the one underneath on my TA I haven't had any troubles so far with the car overheating but I don't drive to many long distances without it at high speeds.
thanks
Old Jul 25, 2012 | 03:18 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
The air dam is only effective at speeds over 35MPH. it's designed to create a low pressure area behind it, allowing air to be "pulled" across the radiator. In traffic and at speeds lower than 35, your car relies on it's cooling fan.
Old Jul 25, 2012 | 09:48 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
That one.
Old Jul 25, 2012 | 10:02 AM
Originally Posted by TreeFiddy
That one.
Thanks, that one I have in place luckily even though it is flapping around
Old Jul 25, 2012 | 07:51 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Someone suggested I build it scoop like, instead of a dam. That way you could raise it up an inch or so so it doesn't hit so many things. Make it out of fibreglass or something. I think the reason it's made out of plastic is so it bends...
Old Jul 25, 2012 | 07:55 PM
nhgator's Avatar
Car: 1985 T/A
Mine is like that,first attempt is still on the car,wraps forward around below the radiator inlet,kinda ******* but works.
Version 2 will be a little smaller and more subtle
edit-wow red part-below-the-head is a forbidden word here.
Old Jul 25, 2012 | 11:40 PM
Blue1990camaro's Avatar
air dam? whats an air dam, i know how dumb i probably sound but its like 1am and im so lost as to what an air dam is....
anyone have a pic they can post with and without it??
Old Jul 26, 2012 | 03:26 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
It's a nearly vertical piece that mounts below the rad - both to direct air up to the front of the rad, and create a low pressure area behind it to remove waste air.
Try some ing... eg first pic in post 6 of this thread:
https://www.thirdgen.org/forums/body...e-air-dam.html
Old Jul 26, 2012 | 02:01 PM
oh ok i know what your talking about, my iroc is missing it, its always run kinda on the warm side, i JUST took it off my sport coupe because i did an RS front end conversion, i didnt think i had to put that on but i gues i will now lol
Old Aug 9, 2012 | 01:05 PM
88I-ROC's Avatar
Car: 1988 Camaro Iroc-Z
Axle/Gears: 3.08
Why you don't go to Camaro Heaven to get an original one? it's in your area...
Old Aug 9, 2012 | 01:24 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
The airdam does enough on my car that if I'm cruising over 35 mph, I turn the fan off. Motor stays at 190 degrees all day long even in 95 degree Florida summer.
Old Aug 9, 2012 | 03:54 PM
nhgator's Avatar
Car: 1985 T/A
I called that place several times looking for various parts,always got "give me your name and number,we'll call back"
Never got a call back,total waste of time,wouldn't bother again.
Old Aug 9, 2012 | 04:36 PM
88I-ROC's Avatar
Axle/Gears: 3.08
Since you live in the area, I would have just drive there, they should have this part for sure. If not, you can go online to thirdgenranch.com they should have it as well
P.S.
I used to live in NH as well,lived in Manchester and worked at the mall in Concord, Steeplegate
Old Aug 10, 2012 | 06:38 AM
nhgator's Avatar
Car: 1985 T/A
I figure,if they can't call back and say we have it,come on up or we don't have it,sorry why should I waste any more time with them?
Old Aug 10, 2012 | 12:13 PM
88I-ROC's Avatar
Axle/Gears: 3.08
Just sayin, I usuallt don't rellay on phone call, I like to go to the place and see for my self, but you should try thirdgenranch anyway, they probably has it.
Old Aug 10, 2012 | 02:34 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
NO way, I thought I had the only Third gen F-body there. I Parked over on the backside of the track.. 80% of the cars were foreign. Honda vans. WOW i cant tell how many of those i saw. heck 6 years ago there was third gens all over. I liked walking through the parking lot checking out what people had for Cars and such, and the women of course but there wasn't much to look at this year...
Oh yea, you live in concord.... you must know of Camaro heaven, I've been there a few times, They can hook you up with whatever you need. Its in Tilton.. pretty easy to find..
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
dyeager535
Aug 28, 2015 08:10 AM
mikey8494
Aug 22, 2015 07:57 PM
92firebirdchris
Aug 14, 2015 11:56 AM
