GM Coolant Tablets
Old Aug 10, 2012 | 03:35 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
GM Coolant Tablets
Well after months of trying to figure out my strange heating issues and replacement of my entire cooling system I broke down and tossed in x2 smashed up GM tablets. Drove the car around for about 15-20 min to letit work and my temp stayed at a steady 180* again. Has anyone else used these? they seemed fairly cheep compared to aftermarket stop leaks but seemed the most safe from my research.
Old Aug 11, 2012 | 08:38 AM
joshc's Avatar
Car: 1986 Trans Am
Re: GM Coolant Tablets
They are make by Bar's Stop leak. According to GM they put a couple in all the new cars on the production lines as a preventative measure against small leaks. They are safe to use in a reasonably well maintained cooling system. Most of the horror stories you hear about them plugging up rads and heater cores are from people with neglected systems that are already half plugged.
Old Aug 13, 2012 | 01:39 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
And, if you own a 4.1/4.5/4.9 Caddy, you better be using them.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
