Help, heater control valve missing
Old Sep 3, 2012 | 02:03 PM
munk20's Avatar
Car: 1991 Z28
took my car in to have the motor rebuilt because it had a compression ring blow in it. at the same time i had them remove all the smog equipment, however for some reason the heater control valve was taken out with all the smog. now im trying to figure out how to get it hooked back up, car is a 91 with L98
found the vac line but they shortened it an plugged it into the plenum (pic attached) so what is supposed to be plugged in here where the heater valve vac is plugged?
also on the return line that runs to the metal tubing on the pass side and into the oil cooler the hose coming out of the metal lines is just capped off with a bolt, will this effect how efficient my cooling is?
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
lakeffect2
Aug 23, 2015 08:44 AM
