a/c delete
Old Oct 30, 2012 | 06:03 PM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
a/c delete
ok here's my question when i put the a/c delete box in do i need to also replace the heater box inside the car.or will every thing still work right without replacing that one?????
Old Oct 30, 2012 | 09:12 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: a/c delete
You'll be fine with the original AC Heater core box and console mounted controller.
Be sure to re-use the original "resistor" that was installed on the top of the AC box and not the 3 pin resisitor from the delete box. That way you've got all the blower speeds that the AC system offers.
About the only draw-back is that the original AC wiring harness will still have the AC plugs on it..... not a big deal !
jrdturbo
Mar 31, 2016 02:58 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Zell1luk
Sep 29, 2015 10:36 AM
