Fans Manually Controlled by Toggles
Car: 1988 GTA
I bought my 1988 GTA and it has 2 toggle switches on the dash that control the cooling fans. The previous owner has said he is convinced that if I want to run the fans off of the temp sensor that I have to trace the ground wires and repair them.
Can someone break this setup down for me? How do I get this back to stock? What parts should I purchase and how is this system supposed to be setup? I just don't know what connects to what.
Car: 1988 GTA
Re: Fans Manually Controlled by Toggles
Yes, TPI car. Is that from the Chilton manual? I looked at it and went crosseyed
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I don't know the origin. As you can see bye the schematic the ecm controls the primary fan . The secondary fan is controlled bye a cts in the block grounding to turn on the secondary fan, I would start from the power supply at the starter the fusible link commonly is damaged or corroded.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
