heater hoses
Car: 91 firebird formula
Engine: 357
Transmission: t5
heater hoses
Ok been trying to research this and haven't came up with much. I have a Carb motor in a 91 firebird and I'm looking to get rid of the heater hoses so my question is do I need to have a return hose running from the intake back to the radiator and if so does it matter if its on the front or on the back side of the intake?
Engine: 4++,350 & 305 CIs
Re: heater hoses
Since your going total race car, You don't even need that hose. plug intake and cap/plug the rad fitting.
Re: heater hoses
The overflow tank? You can, I wouldn't. Coolant needs a place to go when it expands. No tank means it goes on the ground and maybe under a tire. Thats bad. If you cap that little nipple, the psi will build and blowout something
Use a overflow of somekind.
Pac J
May 17, 2020 10:44 AM
