Engine bay heat
Old Apr 8, 2013 | 07:14 PM
Dstrubert11's Avatar
Car: 88 camaro
Engine: 5.7L worked
Engine bay heat
Ok so I have a 88 camaro that i took the fuel injection and computer out and put a carb headers cam intake exc.. The headers are the hooker 2460s. My concern is the engine compartment is crazy hot high engine temp just to hot but everything is working fan and water pump everything is normal. Whats the best way to cool the engine compartment so it can run efficient. I have a vented iroc hood but the vents are non functional. So what are my options header tape? Engine ice? Help!!!
Old Apr 8, 2013 | 07:20 PM
Re: Engine bay heat
Have the headers ceramic coated before you put them on
Old Apr 8, 2013 | 07:33 PM
Car: 88 camaro
Engine: 5.7L worked
Re: Engine bay heat
Ok I do that also is there anything else I can do?
Old Apr 8, 2013 | 09:30 PM
thirdchance's Avatar
Car: 1991 R7U Z28 1LE
Engine: LB9
Axle/Gears: G92 3.42 Truetrac
Re: Engine bay heat
In 86 I had a factory order LB9 TPI and after some issues built a Super Gorilla 406 carb headers...stock rad. I opened up the hood by spacing up the louvers 1/2" and cutting out the hood in the shape that is already there to allow some outflow of hot air. Also removed the fog lights for a small gain....Stock rad. Cooled 10x better than my stock 1965 Vette 396/425 HP with a 3 row rad.
Old Apr 12, 2013 | 03:21 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Engine bay heat
I had my shorty headers ceramic coated, and then I added the wrapping
w/ copper impregnated insulating wrap. I haven't actually driven the
car, but let it set idling for a long time, and engine comp. temp remained
very low.
(Installation of the wrap will be greatly enhanced with stainless steel
ty-wraps available in the electric supplies dept. of H-D & Lowes. )
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
