BWD TFS1 fan switch specs
Old Apr 20, 2013 | 10:31 PM
Mastiff's Avatar
Can anyone confirm? O'Reilley cross referenced this from the GP Sorensen FS1 referenced here:
https://www.thirdgen.org/forums/cool...ernatives.html
I'd like to know for sure that it has the same on/off specs, or at least close. I'm looking for something relatively high temp (like 220) to run the second fan.
Old Apr 20, 2013 | 10:49 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: BWD TFS1 fan switch specs
Might as well keep the stock fan switch if you want it to come on at 220°. The stock fan switch turns the fan on at 235°. That link is partially wrong. Single fan cars don't use fan switches. They're controlled by the ECM.
Old Apr 20, 2013 | 11:07 PM
Mastiff's Avatar
I'm doing a retrofit, there's no stock switch. I just want something with 3/8"x18 threads and a convenient connector type. I have the BWD in hand, but I got nervous that it might not be right temp wise.
Old Apr 20, 2013 | 11:45 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
TFS1 is the stock closing temp - 238* F.
Might be better off with TFS4 - closing temp is 211* F.
Old Apr 21, 2013 | 10:05 AM
Mastiff's Avatar
Okay, thanks. Now I know that the BWD matches the GP Sorensen list I was looking at. Hmm, yeah 238 seems kind of high, but I guess if it was good enough for the factory it should be okay for me. My main concern is to have it well above the temp range fan #1 is working at, which is currently to come on at 203. I'm running the first fan with ECM, second with switch.
krisner89
Oct 10, 2015 06:03 AM
bryanwood74
Sep 24, 2015 09:50 PM
angel2794
Sep 8, 2015 06:22 PM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
