Auxiliary Fan Switch 88 GTA
Old May 1, 2013 | 09:28 AM
Benjamin Hunter's Avatar
I am looking for a wiring diagram to run an auxiliary fan switch for an 88 GTA. Does anyone know if there is an aftermarket pug in or does it have to be done manually?
Old May 8, 2013 | 05:16 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Auxiliary Fan Switch 88 GTA
Welcome to TGO!
Why do you need to run an auxilary fan switch? Does your fan not work?
Old May 8, 2013 | 07:27 AM
I have a 383 stroker in it. The fans run as they should. However, I would like to run them when in staging lanes.
Old May 8, 2013 | 07:52 AM
Ozz1967's Avatar
Car: 1984 Trans Am
As I see it, you really only have a couple of options. 1. Flash the ECM and buy a colder fan switch so the fans turn on sooner. Or, buy a relay kit and wire your own toggle to turn them on, thus bypassing the ECM and factory cooling switch. I don't know how you'd bypass the ECM otherwise. Alternately you could put a colder fan switch in that would turn at least one of the fans on at 185 or 195.
The_Phoenix
Feb 4, 2016 07:10 AM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
TA8487
Aug 16, 2015 12:21 PM
