Help! 89 T/A Fan Wont Run.
Old May 29, 2013 | 04:38 PM
Jaymottv8's Avatar
Car: 89 Trans Am GTA
Transmission: 5 speed
I have a 89 Trans Am GTA, and the fan wont run on its own. The previous owner has rigged a switch under the dash to start the fan. But that is done manually, I want it to run like it was made. I am new to cars and young, I can really need the help to diagnose and fix it! It is a 305 TPI of course!
Old May 29, 2013 | 06:49 PM
Re: Help! 89 T/A Fan Wont Run.
Is the fan switch in the head plugged in?
When you say "won't run", describe the circumstances under which this occurs. (running conditions, temp gauge readings or infrared heat gun readings, stuff like that)
Old May 30, 2013 | 09:33 AM
Jaymottv8's Avatar
Everything is plugged in. I personally think its a bad wire or something like that. When I get home I'll look at those details. I'll also try and upload a photo on what the previous owner did to run the fan manually.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
