cooling circuit fusible link location?
Old Jun 8, 2013 | 08:33 AM
Igorealfast's Avatar
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Ok, I think my fusible link blew. Orange wire, has no power. Where in the harness is the fusible link located? 1988 GTA.
Thank you!
Old Jun 8, 2013 | 09:58 AM
chevelle600's Avatar
Car: '87 IROC-Z/28
Engine: 357 HSR
Axle/Gears: 3:73 w/Eaton Posi
Re: cooling circuit fusible link location?
Mine is right off of the alternator charge wire. Its fairly large, alt goes in one side, same side then goes to battery. Other side one goes to fan plug and other to body harness.
Old Jun 8, 2013 | 10:15 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The one for the cooling relay is probably at the starter.
There is a couple of them there on an '88.
Old Jun 8, 2013 | 10:48 AM
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Well I found it. it's right off the battery.
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
