camaro overheating
Old Jun 24, 2013 | 08:15 PM
  #51
Dinmiller's Avatar
Car: 86 Camaro IROC-Z
Transmission: 5-speed man
Re: camaro overheating
ok t top thats not the test i am doing, im doing one that uses fluid to test to see if there is combustible vaper coming out through the radiator to tell you if you have a blown head gasket
Old Jun 24, 2013 | 08:29 PM
  #52
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Gotcha!!
Old Jun 24, 2013 | 08:38 PM
  #53
Dinmiller's Avatar
I pulled the thermostat completely out, it still over heats, but takes a lot longer, the timing was really , really advanced, so i tried retarding it to the point of dying (everywhere in between and it still over heats. Although it was retarded considerably i seem to have more power.
Old Jun 25, 2013 | 06:42 AM
  #54
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I'd focus on tuning the engine before chasing down over temps. Didn't that come up somewhere before?
Old Jun 25, 2013 | 06:56 AM
  #55
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
what is the current "over heating" temp?
Old Jun 25, 2013 | 12:47 PM
  #56
naf's Avatar
naf
The temp that causes the system to boil over (providing the system maintains adequate pressure).
Old Jun 25, 2013 | 01:15 PM
  #57
Caveman305's Avatar
Engine: L03, LB9
let me rephrase
what is the current temperature this camaro is reading, that is making the OP believe it is overheating if it is not boiling any more
my RS use to run anywhere between 200 and 235(actual temp, gauge would read near red) depending on how hot it was outside, but it wasn't overheating
Old Jul 1, 2013 | 06:51 PM
  #58
Dinmiller's Avatar
Head gaskets are blown, took it apart, also looks like my dumb *** ex step dad put the wrong gaskets on, it appears 2 water jets were blocked on each side by the gasket. I had him do that part because I didnt have the time (he is a mechanic) but obviously not a good one. I am having troubles finding the head gaskets I should be using tho, I have Edelbrock Performer RPM Heads, model is 6037, I guess at some point they added a 9 to the end from what i can tell so, 60739
Old Jul 1, 2013 | 07:08 PM
  #59
Dinmiller's Avatar
Ok I think I know which one it is. The one on the left is the one the idiot put on, and the one on the right is the one that was on before the rebuild. I'm glad i kept them.
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
mustangman65_79
Sep 1, 2015 03:51 PM
jbd1969
Aug 17, 2015 07:06 PM
