temp gauge, overheating?
Old Jul 4, 2013 | 01:39 PM
draco1366's Avatar
just got an 85 Berlinetta in beautiful shape. the temp gauge shows nothing and i feel like the car might be running hot. whwt feeds the guage, and does the fan run off that same info?
and i have not had a chance to go through many of the normal tests yet. just wondered if one problem was a result of the other
Old Jul 4, 2013 | 02:23 PM
Re: temp gauge, overheating?
Temp gauge sending unit: driver's side head, between #1 & #3 spark plugs.
No.
Come to think of it, that TGSU location is for a V8... if it's a 6-cyl I haven't the vaguest clue, as, although I've heard they exist, I've never even seen one up close.
Old Jul 4, 2013 | 02:41 PM
draco1366's Avatar
i have since (sheepishly) realized that it is a belt driven fan (confused it with my '92)
can i remove the belts on my smog and ac pumps without removing the hoses? (temporarily) they are making a lot of undue noise and i was going to pull them anyway
and thanks for the location
Old Jul 5, 2013 | 12:24 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Yes. You can remove the belts without removing the hoses.
Check your temp gage sending wire at the sensor. Make sure it's connected. Test the gage by grounding the wire with the engine in 'run'. The gage should max out.
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
wisemanz28
Sep 20, 2015 01:26 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
