Low Temp Fan Switch Install
Old Jul 10, 2013 | 12:45 PM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
The guy that just rebuilt the engine (L98 350) in my 89 Formula suggested I install this switch (you will have to search for part # 244198 as I couldn't get the link to go directly to it)
http://www.parts123.com/parts123/yb....ort~A2~cadefib
So I ordered the part and was going to install. I'm not very mechanically inclined, but I can follow instructions. The install instructions are attached. So which does my car have a) Electric Cooling Fan Controlled by a Fan Control Switch or b) Electric Cooling Fan(s) Controlled by the ECM/PCM (Computer)?
Thanks,
Chris
Old Jul 10, 2013 | 10:41 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Low Temp Fan Switch Install
You have both actually. But for the piece mentioned above, you will be using the fan controlled by fan switch method.
Drain the coolant, unplug and unscrew the stock fan switch between the #6 and #8 cylinder on the passenger side (you can only see this from below the car). Screw in the new one and plug it back in. Add coolant back to the car.
Old Jul 11, 2013 | 02:01 AM
z28_5.7_TPI's Avatar
Car: 92 Z28 25TH ANN. CAMARO
Engine: 5.7 350
So is this for the passenger side fan ? I'm having a problems, my driver side fan kikd on just fine and at the right time..although my pass. Fan won't come on I changed the fan moter not the Problem ..so IM looking for a switch that Will only trigger that pass. Side fan on by it's self.. Does this switch do that? Do u recommend this switch on a 92 Camaro seeing how it's for a corvette? And is this the best one to get for my situation? Sorry for the noob questions.
Old Jul 11, 2013 | 05:14 AM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
Thanks Reid. I plan on doing this this weekend
Old Jul 15, 2013 | 09:10 AM
nomind's Avatar
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
Based on my memory, so someone please correct me if I'm wrong, on a dual fan setup, one fan kicks on initially. Then, if the car continues to heat up, the second fan will kick in. The second fan should also be the one that turns on when the AC is running.
Old Jul 15, 2013 | 10:59 AM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
https://www.thirdgen.org/forums/cool...ans-arent.html
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
italiano67
Dec 11, 2016 09:21 AM
The_Phoenix
Feb 4, 2016 07:10 AM
TA8487
Aug 16, 2015 12:21 PM
