I want a reliable heater.
Car: '87 Z-28
Engine: LT1-topped 400
I don't know if it's just my rotten luck or if there's a problem with these things, but I've had three heaters go bad and leak in some five combined years of driving thirdgens.
I don't want to have to do this job again only to have another heater give up the ghost two years later. Anyone have a recommendation for the best damn heater core you can get?
Re: I want a reliable heater.
Had the same problem. Seems with the bypass valve, during the summer the coolant sits and corrodes the core. Winter comes and leaks. Replaced 2 in 1 year before bypassing the diverter valve and just having coolant run thru the core all the time. Been 4 years since and no leaks.
Car: 91 Z28
Engine: Super Charged 414 FI Roller Mtr.
Transmission: CK Perf. 4L80E Manual W/Transbrake
Axle/Gears: 9" Ford 3.25
Car: '87 Z-28
All of mine have been brass. Guess I'll start looking into correcting electrolysis and shopping for a new brass one.
Thanks for the help.
Car: 91 Z28
If they have all been brass, than you may be falling victim to the mass produced, I don't give a damn, solder work. Where are they failing, around the tube/tank joints, where tank solders onto the corners or out in the middle of the core?? If in the middle of the core on all, check for electrolysis, if hose connection/tank solder cracking or tank to core seam leaking, take new one to radiator shop and have them test and touch up any solder that seems short or lacking, then retest & install.
Chevykid810
Sep 28, 2015 12:57 PM
