Electric Water Pump Swap / Weight Reduction
Old Jan 14, 2014 | 11:17 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
My car is a street/strip car, I decided this winter to swap it over to an electric water pump to get rid of several brackets, reduce weight, clean up the engine bay, and hopefully drop a tenth or so.
Here is a before shot:
In the spirit of cleaning up the engine bay, I went with a new Alternator bracket. It is an Allen Grove piece, here is a shot of one:
It should be noted that a lot of aftermarket alternator brackets (including this one) do not work with the factory alternator, I wound up buying a Tuff Stuff 100 amp 1 wire alternator with a 6 rib serpentine pulley.
One more before pic:
Progress pics:
Driver's side serpentine bracket removed
Passenger side bracket removed:
Proform Water Pump mocked up:
Allen Grove Bracket Mocked Up:
Bracket Removed, heads painted, bracket reinstalled with alternator:
Finished Product:
You can read more about my build here:
http://burtonracing.blogspot.com/
It should be noted that this is the stock L98 shortblock with a carb and vortec heads on it, the motor has never been out of the car and has 90k miles on it. You can tell the engine bay needs to be cleaned up. I am hoping to hit the 12's with this setup this season before possibly pulling the motor.
Old Jan 15, 2014 | 09:54 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Electric Water Pump Swap / Weight Reduction
nice install! ive been considering running an electric waterpump. is it up to the task for street driving? any cooling problems?
Old Jan 15, 2014 | 11:32 AM
It should be up to the task for street duty, I will know soon enough. It isn't really warm enough out to give it a true test, but for the price and reputation the Proform seems like a good unit. You can also purchase replacement motors for it which is a big plus.
I snapped a few more pictures last night:
Before (front):
After (front):
Before (Passenger Side):
After (Above):
After (driver's):
Old Jan 15, 2014 | 02:31 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
do you happen to have a part number for the belt and bracket?
that sure freed up a lot of space. looks very nice too.
did you take your thermostat out? i thought i saw it was recommended?
did you just wire it to a toggle switch or what?
Old Jan 15, 2014 | 02:51 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Looks like Alan Grove brackets. I run them on a couple of my cars.
http://www.alangrovecomponents.com/Catalog.htm
Old Jan 15, 2014 | 03:56 PM
Yes it is an Alan Grove 235R. Thanks! I went to a 165* Moroso thermostat but left it in, I read to take it out and put in a restrictor, and I read to leave it in, so I am going to leave it in and see how things go.
I put a relay in that controls the water pump, and have the relay activated on an ignition wire. I don't want to forget to turn my water pump on.
Old Jan 15, 2014 | 06:36 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Let us know how you go with it.
Old Jan 27, 2014 | 08:13 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
I've thought about doing this as welll, so I can get rid of the serp brackets and just have alt and powersteering, but from what I read it's mostly for cars that spend more time at idle than they do at cruising speeds. The electric pumps have a set rpm, while belt driven have an rpm that matches engine speed, and also moves more water at certain rpm (can't remember specifically). So I'd be interested to see how it performs on the street.
Old Jan 27, 2014 | 08:16 AM
Car: 1971 Camaro
Engine: 427
^ my 55 has an electric csi pump, it's old, they are csr brand now.
It kept my 11:1 BBC cool on the street with a deck radiator!
Old Jan 27, 2014 | 09:02 AM
Dakota W.'s Avatar
Think it would keep a 500hp sbc with 11:1 with 3row aluminum rad cool?
Old Jan 27, 2014 | 10:10 AM
Car: 1971 Camaro
Engine: 427
I don't see why not. You ever seen the radiator in a 55 chevy? It's a lot smaller then out cars, and a down flow design.
We bracket raced and cruised the 55 with it and never fad a cooling issue.
Had a 16" autozone electric fan and a 170 thermostat.
The BBC was pushing around 600hp.
I'm building a blower motor now, and am upgrading the radiator. But I'm keeping the water pump.
Mine is a 35gpm unit and is about 10 years old now.
Old Jan 27, 2014 | 10:23 AM
Dakota W.'s Avatar
You probably just sold me on an electric water pump then.
Old Jan 27, 2014 | 10:34 AM
sidwyz's Avatar
Car: 1985 IROC-Z
Engine: 355 LT1
Transmission: 4L60
Axle/Gears: 3.23 Australian 9 bolt
Hell me too! I was leary of them because I kept reading about them dying so quick, guys have 2 and 3 of them in the garage just in case because of it. I was thinking the 5-10 HP wasn't worth the peace of mind. But if this brand is 10 years old and still running strong?! I need one!
Old Jan 27, 2014 | 12:13 PM
Car: 1971 Camaro
Engine: 427
^ just to be clear, my 10 year old pump is a CSR brand.
Old Jan 27, 2014 | 01:31 PM
sidwyz's Avatar
Car: 1985 IROC-Z
Engine: 355 LT1
Transmission: 4L60
Sweet, jets has em for my Lt and they are 100.00 cheaper than the meziere brand...I wonder why I've never heard of anyone using these?? Guess I'll be the first
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
