will a code display for a faulty coolant sensor?
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
if the coolant sensor that turns on the coolant fan is faulty, will it display a code or just be faulty and not turn on the fan.
Axle/Gears: no idea
Re: will a code display for a faulty coolant sensor?
ok thank you so much for an answer
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Code Breaker
Not all VINS are the same, and I see he has at least 2 cars.
The Fan Switch is indeed “just an on/off ground switch” however some VINS use a CTS for a fan, which will set code 14 or 15 depending on mode of failure.
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
Happy Racing!
FormulasOnly
Sep 10, 2015 09:07 PM
MikkoV
Sep 9, 2015 04:25 PM
[Sold] T5 electric speed sensor
Eric-86sc
Sep 7, 2015 02:10 PM
