V6 to V8, installing OEM dual fans, what temp on/off for switch?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ordering a fan relay/temp switch/harness install kit and there are many different combos.
83 Firebird with a 350 swap. Running OEM TPI dual fans. Basic setup.
I'm up in New England so most days aren't going to be scorching.
Car isn't driven in the winter.
Won't be seeing much racing, just daily use for the most part.
Options for fans on: 176/180/185/195/210
Options for fans off: 161/165/170/175/190
Was thinking this one: http://www.summitracing.com/parts/sum-890014/overview/
Thoughts?
Thoughts?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: V6 to V8, installing OEM dual fans, what temp on/off for switch?
IMHO,
I'm thinking anything less than 185* is too cold, won't even really let the engine reach operating temp. I'd personally go with a 190 on, 175 off or even a 205* on, 180 off.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok cool, that's exactly what I needed to know. Wasn't sure where the old 350 was happiest!
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
http://www.summitracing.com/parts/rfw-ar99/overview/
Ended up with this one. Fully adjustable! I'll post results soon
eightsixseven
Dec 16, 2024 01:50 PM
The_Phoenix
Feb 4, 2016 07:10 AM
TA8487
Aug 16, 2015 12:21 PM
