Help with cooling fans!!!
Old Apr 30, 2014 | 09:25 PM
jstratouly's Avatar
Car: 88 Iroc Z28
So I just got my 88 Camaro iroc and i realized, after having it delivered sunday, that my cooling fans are hooked up to a toggle switch so i have to manually turn them on and off and the temp gauge is stuck on 110. I know it all has to be rewired. I am in training to be a certified mechanic so I know how to do it correctly as long as I know how the wires are supposed to be routed. Are there any pictures someone has that show how to route the wires, from the sensors to relay to gauge and to the fans? Any help would be appreciated.
Old May 3, 2014 | 10:59 AM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: Help with cooling fans!!!
If you want a superior stand alone version, I can help you out. It's a 3 speed harness that uses your stock GM temp switches and can be used with any single or dual fan setup-stock OEM or aftermarket. I would put this up against any aftermarket kit however, it is fully serviceable at any parts store or GM dealer. PM for details about it.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
