3rd gen radiator with LT1
Old Aug 17, 2014 | 09:09 AM
nickdiesel's Avatar
Car: 1988 Camaro Convertible
Can I just T the oil cooler line into the steam line at the radiator? Seems like the easiest way to do this since Im short one hookup at the radiator.
Old Aug 17, 2014 | 09:13 AM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
Re: 3rd gen radiator with LT1
im not sure without a picture of what your asking, what I do know is oil and steam really don't mix, steam means water, am I missing something here?
Old Aug 17, 2014 | 09:17 AM
nickdiesel's Avatar
That's the bung below the overflow on the rad. The taped one is coming from oil cooler and the obvious hose is the steam line. If that would be ok should be simple
Attached Thumbnails 3rd gen radiator with LT1-forumrunner_20140817_101456.png
Old Aug 17, 2014 | 09:40 AM
I could be wrong, having an oil line and a steam line connected together can not be a good idea in any way!
Old Aug 17, 2014 | 09:53 AM
nickdiesel's Avatar
Pretty sure it just uses coolant to cool the oil but I can't find a diagram
Old Aug 17, 2014 | 09:55 AM
nickdiesel's Avatar
Cuz it is fed off the water pump I believe the line I wanna T in is the return to the rad just not positive
Old Aug 17, 2014 | 06:33 PM
Citation X's Avatar
Car: 92 RS
Yes you can do that. Thats what I did.
Old Aug 18, 2014 | 09:22 AM
nickdiesel's Avatar
No overheating problems and what temp does it run? Are you running factory 180 degree thermostat? Thanks for the reply
Old Aug 19, 2014 | 10:22 PM
Citation X's Avatar
Car: 92 RS
I have an aluminum radiator. Its a champion so its not the best. I had to put some better fans with a shroud on it, but I also am running my tranny cooler through the ac condenser so I get a lot of heat from that. With my 180 stat in, I will get up to 200-210 when running it hard in 95 degree temps. It cools down to about 190ish when normal driving. I have a new air dam coming because mine is warped a bit. I think my fans came off of a Cordoba but not sure they were giving to me. They fit in nice just not sure how much cfm they pull. I was getting 220+ with the camaro dual fan set up with no shroud. My LT isn't stock by any means either so I know it builds up more heat when I get into it.
Old Aug 20, 2014 | 12:28 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
You T into the overflow line for the steam tube. I'd have to look at my LT1 radiator, but I believe the port for it is in the same location as the overflow port.
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Dec 27, 2019 04:14 PM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
