Rust in coolant... again
Old Aug 24, 2014 | 08:29 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Last summer I noticed the coolant in my 89 TA looked rust colored so I flushed it out, then ran a cleaner though it and flushed it again. I took a look at it tonight and it looks as bad as it did last summer again. Its so bad that the inside of the reservoir tank is pure brown even when theres no coolant in it. What is causing this and how worried should I be?
Old Aug 24, 2014 | 11:32 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Re: Rust in coolant... again
Also the petcock on the radiator is leaking. I was just going to try to replace the petcock but would I be better off replacing the radiator? The radiator is aluminum, obviously, so I wouldn't think the rust is coming from there. Or is it?
Old Aug 25, 2014 | 12:55 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
have it flused at a rad shop, rust is from the block, they'll use a mild acid solution till its gone. rust scale could block passages in rad.
Old Aug 25, 2014 | 08:51 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
So is the block rusting from the inside not something to worry to much about?
Old Sep 4, 2014 | 11:45 PM
aramirez121's Avatar
Car: 1991 camaro rs v6
Engine: v6 3.1
Transmission: auto
i got the same problem when i took itin the said what look like mud came out of the rad
Old Sep 5, 2014 | 12:49 AM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Do you have your cooling system grounded at either the heater core or radiator itself? There should be a ground strap on the heater core to firewall I believe. Without it, electrolysis will quickly degrade the coolant and make it caustic to the iron.
Old Sep 5, 2014 | 12:52 AM
Engine: v6 3.1
Transmission: auto
ima have to check because i dont know right now
Old Sep 5, 2014 | 05:29 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
think jcwhitney still sell the old rad caps with a bar of zinc to hang in the rad.
rust or what makes it is alive, if you give it zinc which is much easier to eat, it will eat it instead.
hotwater tanks have zinc rod in them for that, ships at sea bolt giant hunks of it to the outter hull.
Old Sep 5, 2014 | 06:56 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
or use a proper solution of antifreeze and distilled water.
those petcocks commonly fail and a new radiator is relatively inexpensive. inspect your rad and if it's crusted up, consider a new one.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
