Ac on but fan OFF ?
Old Sep 24, 2014 | 12:11 PM
claus290373's Avatar
Car: Trans Am gta 5.7 1989
Engine: 350 tpi
Transmission: th700r4
Axle/Gears: BG 9 bolt
Ac on but fan OFF ?
Then i turn the ac on the fan dosnt kick in is that right ?
I have 2 fans on my 5.7 tpi
On my European car the fan always run with the ac on
Old Sep 24, 2014 | 01:14 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Ac on but fan OFF ?
No, That's not right. Read this thread. Also secondary fan or passenger side fan will/should come on computer controlled at 240 ish degrees AND when AC is on.
https://www.thirdgen.org/forums/cool...enger+side+fan
Old Sep 24, 2014 | 01:42 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
The primary fan in those cars is controlled by the ECM and the secondary fan is run by the Fan Switch, IIRC. Both fans should come on with the AC.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
