Fan problems
Old Mar 19, 2015 | 08:57 PM
91TransAmVert's Avatar
Car: 1991 Trans Am Convertible
Engine: 5.0 TPI
Fan problems
I have a 1991 Trans Am 305 tpi and recently the radiator fan has stopped coming on. I have tried to fix the problem myself, but have not had much luck. The wiring was all redone and a fan switch installed by the previous owner so I can't just look into a book to figure out how to fix it. The driver side is the only one that was coming on, the passenger side fan hasn't kicked in since i got it. So i was hoping someone had a guide to install my own fan switch so i can do it from scratch and not have to worry about if the last guy didn't ground something right or something. Also what would be the possibility that the fan motor just burnt out? If there was a way to check if the motor is even operational. Open to all suggestions and criticism.
Old Mar 20, 2015 | 01:29 PM
Engine: 5.0 TPI
Re: Fan problems
Nevermind, a few buddies came over and i fixed the problem a few minutes ago.
krisner89
Oct 10, 2015 06:03 AM
utfan01ss
Sep 28, 2015 12:17 PM
Papaginos
Sep 27, 2015 03:29 PM
JHX
Aug 29, 2015 02:30 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
