COOLING FANS ???
Old Mar 26, 2015 | 05:29 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
COOLING FANS ???
while doing a little cleaning and checking last week , I noticed my cooling fan came on when defrost selected . I know they should/do come on when A/C is selected . maybe I just never noticed before . does anyone know if they should come on when defrost selected ??? thanks in advance ...
Old Mar 26, 2015 | 06:01 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: COOLING FANS ???
If the compressor gets cycled (which it does when you select defrost mode) it triggers the fan relay. Newer vehicles usually use a trinary switch circuit in place of this method.
Old Mar 27, 2015 | 05:51 PM
UNCLE TOM's Avatar
thanks , never too old to learn (damn I'm old) .
Old Mar 30, 2015 | 11:15 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
My 84 turns the fan on when defrost is selected. /shrug
Old Mar 31, 2015 | 08:57 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
In defrost mode the AC compressor runs to provide de-humidified air if the outside temperature is above 40F. When the compressor is running the engine cooling fan(s) will run as well.
De-humidified air helps clear the inside of the windshield.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
