Homebuilt Single Fan Shroud...
Old Dec 12, 2015 | 11:22 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
...I made this in hopes of improving the cooling system. Ive been reading that a shroud should be used, but our electric fan/s don't have one & not really interested in converting to dual fans, so I made this. Those of you who know. What do you think it will do? A lot, a little, nothing at all? I don't have any real world use yet, as the car is in transition. Stock 17" fan, champion rad, never ran hot before.
Minimal gaps.
Old Dec 12, 2015 | 11:45 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Homebuilt Single Fan Shroud...
Looks nice however you do need to little space between the shroud and the radiator to allow air flow into the shroud.
Old Dec 12, 2015 | 11:55 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
There's at least 1" on the outer side, to almost 2" at the fan.Thats probably at the minimum for airflow, i think.
Old Dec 13, 2015 | 05:40 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
nice job on that shroud-has to improve airflow at idle/low speed-but could possibly restrict radiator airflow at high speeds as a "windmilling" fan restricts airflow and the factory may have left the sides open to "spill" air at high speed.IIRC,the '84 'vette,with the exact same fan,has a shroud almost completely enclosed except the lower corners of the radiator-so might not be a problem.
Old Dec 13, 2015 | 06:18 PM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
If it works noticeably, Make me 2 sets...
Old Dec 13, 2015 | 07:58 PM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
Very intrested in to see how this works out
Old Dec 13, 2015 | 08:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I was thinking the same thing while cutting these.Ill have to wait & see how it performs.I can always cut a few slots in it if it restricts airflow at speed.Ill have to find a pic of the vette set-up.
Old Dec 14, 2015 | 01:55 AM
Twin_Turbo's Avatar
very nice. Do you have cad drawings for this or did you make it as you went? Very professional looking with the bends and all.
If anything you could holesaw a couple of holes on each side and rivet a rubber flap over them like many of the aftermarket and OEM shrouds use
Old Dec 14, 2015 | 09:31 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks T_T. My drawings consist of cardboard & sharpie, template. Then transfer to sheet metal. Eyeballed & hand bent mostly. The vette piece looks pretty involved, but i like your rubber flap idea.
Old Dec 14, 2015 | 09:48 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Great work on the shroud. Seeing your work, makes me want to go back to single fan.
Old Dec 14, 2015 | 09:52 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Old Dec 16, 2015 | 04:57 PM
AmorgetRS's Avatar
Wow, that looks brilliant! Amazing that you did that by hand.
Old Dec 16, 2015 | 09:57 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yeah, that & my so-called CAI.All handmade, on account I'm too cheap to buy!Thanks btw.Been thinking about making that trap door..before I put this on the road.At least on the passenger side anyway.
Old Dec 27, 2015 | 09:59 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
So I decided to put some vents on the shroud.They are spring loaded, so they close when not in motion.I also upgraded to a Spal fan (#30102049).
I mounted the spal fan by cutting out the center of the OE fan mount. I used six small bolts/nut to hold the spal fan in place .You can see two of the nuts/bolts here.
Mounts same as stock, slightly roomier w/ 2050 cfm to boot.
Old Dec 28, 2015 | 12:22 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Looks great.
Old Dec 28, 2015 | 04:28 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Nice!
Old Dec 30, 2015 | 11:12 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks guys.
Old Apr 24, 2016 | 12:06 PM
coren's Avatar
How much will you charge me for a pair with the door spring activated?
Coren
Old May 9, 2018 | 04:03 AM
RaceFace's Avatar
Car: 1987 F-bird
Engine: 350 Vortec
Transmission: Manual
84 1LE, how's the result, worth fabricating shrouds?
Old May 9, 2018 | 08:45 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yes, definately.Most helpful when the car is stopped, not as much while at speed, but that what shrouds are meant for anyway.I cant complain though.
Old May 10, 2018 | 12:53 AM
NoEmissions84TA's Avatar
Very nice.
Fast355
Oct 3, 2022 07:15 PM
miche25
Mar 10, 2019 11:13 PM
3rdgenmaro
Aug 30, 2012 11:03 AM
icebird_1981
Aug 25, 2004 12:01 AM
86IROCZ
May 31, 2002 04:51 PM
