Help with my AC.
Old May 28, 2016 | 10:15 AM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Help with my AC.
So I'm going to do a 4th gen condenser swap but while I'm getting the lines made and all that I'm just getting my factory system working so I won't die while driving. I replaced my Compressor, accumulator and orifice tube to a ford blue one. Put 2 and a half cans of freon in. At idle my low side is at 34 and my high side is at 160. Its 82 degrees out and I'm only getting 69.7 degree air out of the vents. So something is wrong. It's sweating up to the compressor and my preasures look ok. I have duel fans from a 4th gen so air flow isn't a problem. Any ideas?
Old May 28, 2016 | 12:45 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Help with my AC.
Are you sure the temperature control/door is working properly?
Old May 28, 2016 | 12:55 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Man that helped a lot!!!
Some reason when push the tab all the way to cold it doesn't shut the door all the way. And if I adjust the cable enough to get it to work when I go to put it on hot it goes in the middle and the door is all ready shut. I think my heater control panel is dead
'91CamaroRS
Car Audio
Apr 3, 2016 07:45 PM
thebossmanscot
Mar 27, 2016 11:11 AM
thebossmanscot
Mar 27, 2016 05:29 AM
tognabologna87
Mar 24, 2016 04:41 AM
omarcamaro
Wheels and Tires
Mar 20, 2016 04:47 PM
