Smoke coming out defroster vent
Car: 89 Firebird - base
Engine: 305 TBI
I went to turn on the defroster the other day, and smoke (not steam or antifreeze) started pouring out the defroster vents. I read that it could be an issue with the AC compressor, but not sure what to check (or how to check it).
Any help/thoughts/suggestions would be appreciated. This is a car my son bought and we have been working on it (and learning) together. I am by no means a mechanic, but cash is tight and we are trying to learn (he is 15 and will be well served to learn).
A defroster in CT is essential (heat doesn't suck either).
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Smoke coming out defroster vent
smoke out the vents likely came from something "cooking off"the blower resistor-especially if car hasn't been used in years or from the blower motor if it is stiff and getting hot or brushes are worn down and arcing.
Car: '82 z28
Engine: L83 5.7
the resistor can be taken out and checked for debris(a fire could start if there are leaves or a mouse nest against the resistor)The blower motor can be replaced if it is the source of the smoke.
Engine: 305 TBI
Right on the mark, pulled the resistor and there was junk on it (yup, now I get to figure out of the mouse house is bigger/worse than I thought). No smoke now though. The fan/blower must be weak because I don't get much air out of the defroster, guess I will have to check the blower motor. Thanks for your help, really appreciate it.
