Boostec oil cooler
Car: 84 Z28
Engine: 383 Stroker
Boostec oil cooler
Hey all, Is this a decent oil cooler? I'm going to use for my tran.
http://www.ebay.com/itm/BOOSTEC-19-R...5VbKq0&vxp=mtr
Thanks all.
Thanks all.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Boostec oil cooler
Looks ok. That 10AN input and output is HUGE though. You'll have to get adapters to use with your radiator cooler. Run the trans coolant through the radiator first and then to the cooler for added cooling.
Car: 84 Z28
Engine: 383 Stroker
Thanks for the reply, I found one that is 6an. Yeah, 10an is too big. lol. I also found the same cooler for cheaper after I bought this. Boostec puts their name on it and marks it up. I plan this weekend to drop engine and tran in and start plumbing.
