Two Fan Issues
Old Mar 20, 2017 | 10:55 AM
kirkcomer's Avatar
Car: 89 Formula 350 Original Owner
Engine: 5.7
Two Fan Issues
I have two problems is anyone can help point me in the right direction.
1988 GTA with push button climate control
1) Climate control blower fan will only work when the "high" button speed is pushed. The other speed buttons light comes on when pushed but the fan turns off.
2) Passenger side electric cooling fan stays on all the time. No matter what I do I can't seem to find a way to turn it off.
Thanks in advance for any suggestions.
-Kirk
Old Mar 20, 2017 | 11:06 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Two Fan Issues
Sounds like the switch is bad causing the ecm to think ac is requested.
Power from the fan switch goes to the blower motor resister located under the hood in the blower housing. High is full power to the motor relay . All other speeds modes go through the resisters as seen on the schematic. The ecm controls the fan relay located on the drivers side next to the master cylinder. If not found there it might be next to the radiator on the core support.
When fan request is the ecm grounds the fan relay to turn on the secondary fan.
http://austinthirdgen.org/mkportal/m..._continued.gif
See schematic for secondary fan control, not pictured the head switch between cylinder 6&8 if grounded the fan will come on . This is a grey wire, not to be confused with the fuel pump relay grey wire power to the pump.
https://www.thirdgen.org/forums/dfi-...r-ecm-bad.html
Last edited by Tuned Performance; Mar 20, 2017 at 12:00 PM. Reason: Fan information
Old Mar 20, 2017 | 12:28 PM
kirkcomer's Avatar
Engine: 5.7
Re: Two Fan Issues
Thanks! I'll check out the links you sent me tonight. I did put a new resistor in. Here is the link:
http://m.autozone.com/cooling-heating-and-climate-control/blower-motor-resistor/dorman-blower-motor-resistor//pontiac/trans-am/1988/8-cylinders-8-5-7l-fi-ohv/530468_0_0?location=
Im guessing the same resistor works for the push button and the regular type climate controls? If not what should I purchase?
Old Mar 20, 2017 | 12:30 PM
Engine: Lb9
Transmission: M20
Re: Two Fan Issues
I would assume they use the same resistor pack.
For testing lo is yellow, tan is the next speed followed bye light blue then full speed through the relay is orange. Hth
Old Mar 20, 2017 | 12:32 PM
kirkcomer's Avatar
Engine: 5.7
Re: Two Fan Issues
Gotcha. I installed the resistor like is in the link but it didnt help any.
