Convert A/C mount to pass side-85 Camaro
Old Mar 29, 2017 | 10:24 AM
tom1985's Avatar
Car: 85 Camaro /65 Lemans
Engine: 305 vin H / 396-375 hp (Real)
Transmission: 700R4 / 4sp
Axle/Gears: 3.08 posi / 4.88 posi
Hi all
I have an 85 camaro 305 vin h with A/C and all emissions removed. Saw a trans am with pass side a/c mount which is a much better design than the 85 camaro goofy/ugly design/routing with the compressor on the drivers side and hoses running around and over radiator to firewall on pass side.
Looking for guidance on what I need to do, what year camaro’s may have had this pass mount, brackets fitment with 85 305, etc to convert to the pass side mount
Thanks in advance for your help
Old Mar 29, 2017 | 04:11 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Convert A/C mount to pass side-85 Camaro
You can use the 88-92 serpentine setup.
Old Apr 12, 2017 | 09:47 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
What tuned performance said. I have a set for sale if interested. AC, AIR delete, Alternator and power steering pump and the brackets. Shoot me a PM. I even have two belts. I'm swapping to LS so I don't need them anymore.
