5.7TPI 1990 Need water pump that is direct bolt on
Old May 6, 2017 | 04:18 PM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
Looking for P/N for 1990 IROC-Z 5.7tpi aluminum water pump that will bolt on to L98 with air pump and A/C brackets with no interference problems. Running into alot of trouble with pumps that dont fit. Anybody have a P/N for a reliable aluminum pump that fits?
Old May 6, 2017 | 08:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 5.7TPI 1990 Need water pump that is direct bolt on
The application listing shows it will fit.
Sbc reverse rotation long pump
https://www.summitracing.com/parts/e...t/model/camaro
Old May 7, 2017 | 06:19 AM
DRIVE2FAST's Avatar
Thanx Ill check it out.
