A/C high pressure cutoff switch replacement
Old Jun 7, 2017 | 12:29 AM
JunJun's Avatar
Car: 92 camaro convertible z28
Transmission: Swapped from 700R4 to T5
Axle/Gears: Stock Posi. Ratio is not known
Is it necessary to discharge the gas in order to replace the high pressure cutoff switch?
Or are there any ways to replace it without discharging the gas?
Attached Thumbnails A/C high pressure cutoff switch replacement-highpressureacswitch.jpg
Old Jun 7, 2017 | 04:29 AM
Re: A/C high pressure cutoff switch replacement
It exposes a hole in the compressor, looking right directly into the high-pressure (output) chamber where the line hooks up.
So, no unfortunately, removing it lets out the refrigerant.
Old Jun 8, 2017 | 06:39 AM
JunJun's Avatar
Thanks for the reply.
I thought I might be able to replace the switch even while the gas was coming out, but probably I was wrong.
Old Jun 8, 2017 | 07:29 AM
Think... it has to be exposed to the pressure, in order to respond to it.
When you put it back in, be careful to clean up the bore of the hole, to get a good seal on its O-ring.
